取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
8
回复
Cisco 2960S CRC
tim20110612
Does the CRC in Cisco equipment refer to bytes or bits? Thank you very much!
Cisco-2960S#show interfaces tenGigabitEthernet 1/0/1
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is f4ea.67c3.4733 (bia f4ea.67c3.4733)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
input flow-control is off, output flow-control is unsupported
Last input 6w3d, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 84000 bits/sec, 28 packets/sec
5 minute output rate 377000 bits/sec, 42 packets/sec
5677611107 packets input, 4615005164223 bytes, 0 no buffer
Received 9511218 broadcasts (8134244 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8134244 multicast, 0 pause input
4631164422 packets output, 2738446223272 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2 个已接受解答
已接受的解答
Jens Albrecht
Level 7
Level 7
Hello @tim20110612,
in fact the CRC count refers to the number of Ethernet frames received with a failed CRC check—not individual bits or bytes.
So your example showing '1 CRC' in the output means one frame with a CRC failure was detected.
HTH!
在原帖中查看解决方案
Hello @tim20110612,
you are welcome!
In case you are interested, the reason is fairly simple. CRC calculates a checksum over the entire incoming frame. If the checksum does not match there is no way to know whether just a single bit or multiple bits were changed. You only know that 'something' is different.
Hence you can only count the number of frames that failed the check.
HTH!
在原帖中查看解决方案
8 条回复8
Jens Albrecht
Level 7
Level 7
Hello @tim20110612,
HTH!
Thanks Jens!
Hello @tim20110612,
you are welcome!
HTH!
Hello Jens, Your answer is very detailed. Thank you.
balaji.bandi
Try clear the counters again and observe - see is that CRC errors appears again before going in to deep investigation.
BB
Thanks Balaji
快捷链接
