Q1: regarding what features can OpenSSL be used for ? I check as following, is it correct, please kindly correct me.
Router and Switches
SSL only used with the following features:
・SSLVPN feature(for any platform running IOS)("webvpn gateway")
・SSLVPN feature(for CRS1000V runnning IOS-XE)("crypto ssl profile")
・HTTPS client feature ("copy https://... ...",DynDNS client,...)
・Voice-XML HTTPS client feature
・HTTPS server
Q2: could somebody help me answer the below questions ?
Product ID |
OS |
Supported OpenSSL versions |
is it possible to disable OpenSSl and what's the command to disable it |
Impact of disabling OpenSSL |
ASR1006 |
15.5(3)S6 |
SSL3.0, right ? |
ASR1001-X |
3.16.6S |
SSL3.0, right ? |
ASR1006 |
3.16.6S |
SSL3.0, right ? |
ASR1006 |
3.4.2S |
SSL3.0, right ? |
ASR1006 |
3.1.2S |
SSL3.0, right ? |
WS-C4500X |
3.6.4.E |
please kindly tell me |
Hope to get your support.
Best regards,
Dan Xu
