Hello,Does the CRC in Cisco equipment refer to bytes or bits? Thank you very much!Cisco-2960S#show interfaces tenGigabitEthernet 1/0/1TenGigabitEthernet1/0/1 is up, line protocol is up (connected)Hardware is Ten Gigabit Ethernet, address is f4ea.67c3...
Hi我连接到公司VPN WEB界面,通过WEB界面下载了一个AnyConnect客户端,AnyConnect版本是:4.10.02086。首次安装到笔记本上是能够打开正常使用的,当把笔记本重启后再次打开AnyConnect客户端,就开始报错:The VPN Service is not available. Exiting.这个时候我得把这个客户端卸载,再次重新安装一遍才可以使用。
目前在用cisco C1100系列路由器,具体型号为C1111-4P,具体配置如下Current configuration : 12558 bytes ! ! Last configuration change at 15:52:46 UTC Sat Jul 12 2025 by admin ! NVRAM config last updated at 15:49:06 UTC Sat Jul 12 2025 by admin ! version 17.16 service timestamp...
BUNDLE 模式,已抄IOS文件到2台3850 flash,1, 是否要將旧起动文件去掉3850_2F_Core(config)# no boot system switch all flash:/cat3k_caa-universalk9.16.03.06.SPA.bin 加上新的起动文件就可以3850_2F_Core(config)# boot system switch all flash:/cat3k_caa-universalk9.16.12.07.SPA.bin 2, 已抄I...
很棘手的问题,整个过程如下:两个月前,我在家里的电脑(win11)本来能正常使用的anyconnect,提示 vpn services is not available无法使用,我按论坛中的方法,重启cisco anyconnect服务(能启动成功)、重装anyconnect,改UTF -8设置,关闭ICS服务等等,论坛中能找到的都试了都没有解决,最后我重装了系统(仅重装了C盘,其他盘没有清理),暂时解决了问题,但是1周后又复发,我再次重装系统,1周后继续复发,于是我彻底重装了电脑(全部硬盘格式...
The customer needs to purchase an MX67.According to the 《MX Series Datasheet》,I have the following questions: 1,Does the device include a power adapter by default, or the power adapter needs to be purchased separately? 2,Does the power adapter includ...
