取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
7
回复
扫码枪无法搜索到2.4g信号,5g可以,其他终端可以正常搜索到
shame
1 个已接受解答
已接受的解答
shame
谢谢大家,我把operational ratel 的低速率从disabled调整为Mandatonry开启就可以了。
在原帖中查看解决方案
7 条回复7
Leo Laohoo
What is the model of the APs used?
The ap mode that can search for wifi signals is local, and the one that can't is flex.
shame
Another phenomenon is that it can't search the 2.4g in the warehouse of building A, but it can search it when it gets to the warehouse of building B. Building B uses another AP model from Cisco , on another AC.
Leo Laohoo
If the AP in Warehouse A supports micro-Radio and Flexible Radio Assignment (FRA) is enabled, then the APs in Warehouse A must have 2.4 Ghz automatically turned off.
shame_0-1727253653536.jpegI set the 2.4g profile in RF to Global config and it connects fine, is there any difference in this default configuration?
424152042
有的扫码枪,只支持5G射频。可以看看扫码枪厂家的参数吧
shame
快捷链接
