你好,
Cisco 1850 Series Mobility Express Release 8.10 Software,to be used for conversion from Lightweight Access Points only.
AIR-AP1850-K9-8-10-151-0.tar 《这个镜像是用作AP的转换的,例如从LAP转换为Mobility Express AP》
Cisco 1850 Series Mobility Express Release 8.10 Software. Access Point image bundle, to be used for software update and/or supported access points images.
AIR-AP1850-K9-ME-8-10-151-0.zip《这个镜像是用作AP Bundle镜像的,所以需要使用这个镜像》
已发送给你邮箱!
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
