custom.ribbon_feed
取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
7
回复
AIR-AP1572eac-h-k9的ciscoAP的默认帐号及密码
jianwen555
有那位兄弟,可以指点一下的,AIR-AP1572eac-h-k9的ciscoAP的默认帐号及密码
1 个已接受解答
已接受的解答
我也没搞过室外的大家伙,
你参考一下连接里面的设备图,找到Reset按钮,接上console,按住reset键,然后再给设备加电试试。通常是等到灯变成闪烁的琥珀色松开按键(大概按住2-3秒左右),最好还是同时看着console的输出来。(RESET应该是有个胶圈螺丝,需要单独拧开,然后用支笔或者小螺丝刀按住reset键。)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/1570-DG/b_Aironet_AP1570_DG.html?referring_site=RE&pos=1&page=https://www.cisco.com/c/en/us/support/wireless/aironet-1572eac-outdoor-access-point/model.html
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1570/installation/guide/1570hig/1570_chtroubleshoot.html
IOS Bootloader - Starting system.
flash is writable
Antigua Lite Board P2
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 76 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 22493184
flashfs[0]: Bytes available: 18665472
flashfs[0]: flashfs fsck took 11 seconds.
Base Ethernet MAC address: 00:62:11:11:11:11
Ethernet speed is 1000 Mb - FULL Duplex
button pressed for 2 seconds   <-------
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
40MB format
在原帖中查看解决方案
7 条回复7
Xiang
Cisco/Cisco试一下
ilay
默认的用户名密码是Cisco/Cisco,密码首字母大写。
如果AP已经注册到控制器,通常情况下会禁止使用默认密码登录,前面密码有可能无法使用,建议使用WLC全局配置的用户名密码进行登录(使用telnet或者ssh登录需要全局启用,或者在AP上单独启用)
兄弟有没有可以把这台AP的console的帐号密码破解了?在线等
胖AP的模式:
-断开电源
-按住MODE键加电
-一直等到AP的状态灯变成琥珀色1-2秒后,松开MODE键
瘦AP可直接将其注册到一个WLC上,下发新的登陆凭据即可
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/atnms-ap-8x/configuration/guide/cg-book/cg-chap4-first.html
哥们,我那台型号是AIR-AP1572EAC-H-K9,没有看到mode键或者是release键,console的帐号密码又进不去。。。。
我也没搞过室外的大家伙,
flash is writable
40MB format
executing...
40MB format
感谢
快捷链接
