取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
air-cap3602i-c-k9想刷成胖AP
tonydai
我是AP小白,想问问有这个型号的胖AP固件吗?最好也有刷的教程。麻烦大神了感激
5 条回复5
Terence.Jh
Re: Convert a 2602i from lightweight to autonomous?
Hi Mantej,
It does not work with these new APs 1600/2600.
You need to perform these steps:
· Restart the Access Point
· While it loads the image in flash, press Escape, you’ll enter ROMMON mode:
The system boot has been aborted. The following
commands will finish loading the operating system
software:
ether_init
tftp_init
boot
· Set the IP address for the gigabit 0 interface:
ap: set IP_ADDR 10.0.0.1
ap: set netmask 255.255.255.0
· Initialize the tftp, ethernet and flash subsystems:
ap: tftp_init
tftp_init success: You can now use tftp file system!
ap: ether_init
Initializing ethernet port 0...
Ethernet speed is 100 Mb - FULL Duplex
ap: flash_init
Initializing Flash...
...The flash is already initialized.
· Load the image from TFTP and extract it to flash:
ap: tar -xtract tftp://10.0.0.100/ap3g2-k9w7-tar.152-2.JB.tar flash
· After it’s done, set the correct bootimage:
ap: set BOOT flash:/ap3g2-k9w7-mx.152-2.JB/ap3g2-k9w7-xx.152-2.JB
· Boot the system:
ap: boot
镜像自己去下
tonydai
Hi Mantej,
就是不知道哪里可以下载,很多地方都下载不了,都需要注册充值
Terence.Jh
从哪里买的就去找谁,如果没有,那就联系代理商买续保后下载
fortune
这个我这里也没有,最近都没权限下载了, 你直接找你的供应商拿,他们必须有
sijle
不支持胖AP
入门指南
使用上面的搜索栏输入关键字、短语或问题,搜索问题的答案。
快捷链接
