Hi Cisco IoT Community,I’m integrating temperature/humidity sensors with a Cisco IE-3400 (IOS-XE 17.9.1) to send data to an AWS MQTT broker via an IOx container running a Python script. Sensors connect via Modbus RTU (RS-485 to Ethernet gateway) on V...
Hello,Does the CRC in Cisco equipment refer to bytes or bits? Thank you very much!Cisco-2960S#show interfaces tenGigabitEthernet 1/0/1TenGigabitEthernet1/0/1 is up, line protocol is up (connected)Hardware is Ten Gigabit Ethernet, address is f4ea.67c3...
目前在用cisco C1100系列路由器,具体型号为C1111-4P,具体配置如下Current configuration : 12558 bytes ! ! Last configuration change at 15:52:46 UTC Sat Jul 12 2025 by admin ! NVRAM config last updated at 15:49:06 UTC Sat Jul 12 2025 by admin ! version 17.16 service timestamp...
BUNDLE 模式,已抄IOS文件到2台3850 flash,1, 是否要將旧起动文件去掉3850_2F_Core(config)# no boot system switch all flash:/cat3k_caa-universalk9.16.03.06.SPA.bin 加上新的起动文件就可以3850_2F_Core(config)# boot system switch all flash:/cat3k_caa-universalk9.16.12.07.SPA.bin 2, 已抄I...
各位老师,今天在做一台思科2911路由器iso升级时遇到一个问题,希望了解的老师可以帮忙指导一下,谢谢!问题如下:路由器现有系统版本为15.2.4M6,希望升级为15.7.3M7,在使用命令boot system flash c2900-universalk9-mz.SPA.157-3.M7.bin之后,重启时看到如图所示的报错‘Signature DID NOT VERIFY’,使用verify命令验证该bin文件时显示如图所示的特征码不存在。出现这个错误是因为镜像文件下载有问题吗?需要重新下...
