Did anyone know if Cisco have templates for equipment preservation plan which may contain long- and short-term storage conditions, lifting and handling recommendations, packing, storage environment... etc.If yes, where can I find it. If not is all of...
Hello-. I am wondering if anyone could help solve a Telnet, SSH, and HTTPS connection problem between two remotely connected ASAs (firepower 1150), some intermediate devices to help connectivity between the two ASAs. Clearly Ping and Traceroute works...
Why do we keep fixing BGP with duct tape? What if we could replace 7 extra layers... with just one smart layer? We all know BGP wasn’t designed for: Fast failure detection Route stability Real-time performance metrics Intelligent rerouting So we bui...
boa noite eu me inscrevi para 10ª Maratona CiberEducação Cisco Brasil, mas não estou achando onde começa a Maratona poderia disponibilizar o link correto por favor ?
Cat 9300L Reading another thread because I needed to wipe the switch. They recommended "Factory reset all" well now I have a switch with nothing butswitch:I've tried to restart to get to romon but nothing seems to affect itSystem Bootstrap, Version 1...
i am trying to access partner account port since couple of hours, however i am getting error 502 Bad gateway.Not sure if any issue with the portal or any issue from my end. tried different browser and different PC as well still issue is same.
Dear Community Team,I hope this message finds you well.I have recently observed an influx of logs in our syslog server attributed to "Console user" and "unknown user." After thoroughly investigating, I could not locate these users in our network or c...
Eu terminei o curso de AI Fundamentals with IBM SkillsBuild pela Cisco Networking Academy mas ele não mandou nenhuma badge e ainda mostra na barra de progressão como se não tivesse terminado , alguém sabe como resolver?meu email é: pacocagui2004@gmai...
I already created subinterfaces, encapsulate, setup each ip address of terminals, the connection between switch and router is on trunk mode but I still can't ping other terminal with the same vlan on other switches(I can ping vlan 10 terminals on the...
I need to verify if a given Cisco-made product or component is certified for a given country. Different countries have different regulatory standards, and the hardest thing to find is whether or not a given component is green-lit by a given governme...
Hello PleaseI took a couple of courses last year on your platformI got some badges when I tried to transfer the transcript to my schoolIt was rejected because they do not have an ACE endorsementHow can these be fixed
Hello, I have two questions and need clarification on some aspects of OSPF. I would greatly appreciate any help in this regard.1 : Router XR in an OSPF network area receives an LSA concerning link L1 from router YR but excludes this information from ...
