Cisco ACI Nexus Part ID Naming Convention
ITforever
Does anyone know any doco explaining what all the letters/numbers mean in Nexus Part IDs?
Example:
N9K-C93180YC-EX
N9K-C93108TC-EX
N9K-C93180LC-EX
N9K-C93180YC-FX
So what is T, L, Y, FX vs EX?
Thanks.
2 Accepted Solutions
Jenny Ngo
The naming convention can be mostly found in this doc: https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-739134.html#_Toc484532920
Following the naming conventions for the Cisco Nexus 9000 Series, the characters in the Cisco Nexus 9300-EX platform product names indicate supported port speeds or additional hardware capabilities:
●   Q: Native 40-Gbps front-panel ports
●   Y: Native 25-Gbps front-panel ports
●   C: Native 100-Gbps front-panel ports
●   L: Native 50-Gbps front-panel ports
●   T: 100M, 1GT, and 10GT
●   X (after the hyphen): Cisco NetFlow and data analytics capabilities
As for -EX and -FX in general, they are using different ASICs.
Jenny Ngo
Robert Burns
T/P/Y - done the PHY type (Copper, Optic and speed etc).
T = BaseT
P = SPF+
Y = Fiber ports
The last notation (E/EX/FX) designates the generation of switch (ASIC capability).
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-736651.html
Robert
Jenny Ngo
Jenny Ngo
Robert Burns
T = BaseT
P = SPF+
Y = Fiber ports
Robert
