This question is about NDO (latest versions 4.x) best practices and supported scenarios.
See https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2022/pdf/BRKDCN-2480a.pdf page 29.
Here we have the same "ANP1" present in all of the templates.
Is this really supported (and recommended)? I have tested this once and ran into issues.
We have a problem. We need to change EPGs between site 1,2,3 and stretched frequently. E.g. today EPG1 may be site 1 local and tomorrow we need to stretch it to all sites.
Basically NDO supports migrating EPG and BD between templates (e.g. from site1 to stretched). But migration between APs is not supported. So if templates have different APs (no single AP spans all templates) the migration becomes lot more difficult.
Which configuration would you recommend in this kind of situation?
