11-07-2022 06:41 AM
Is possible to configure a remote leaf with spine N9K-C9332C cisco aci ?
Solved! Go to Solution.
11-08-2022 02:24 AM
Hi @username11
Yes it is supported.
Here is the config guide: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/5-x/l3-configuration/cisco-apic-layer-3-networking-configuration-guide-50x/m_remote_leaf_switches_v2.html
For the spine switch at the ACI Main Datacenter that is connected to the WAN router, the following spine switches are supported:
Fixed spine switches Cisco Nexus 9000 series:
N9K-C9316D-GX
N9K-C9332C
N9K-C9364C
N9K-C9364C-GX
For modular spine switches, only Cisco Nexus 9000 series switches with names that end in EX, and later (for example, N9K-X9732C-EX ) are supported.
Older generation spine switches, such as the fixed spine switch N9K-C9336PQ or modular spine switches with the N9K-X9736PQ linecard are supported in the Main Datacenter, but only next generation spine switches are supported to connect to the WAN.
Take care,
Sergiu
11-08-2022 02:24 AM
Hi @username11
N9K-C9316D-GX
N9K-C9332C
N9K-C9364C
N9K-C9364C-GX
Take care,
Sergiu
