Showing results forĀ
Search instead forĀ
Did you mean:Ā
Assign UUI to call variables
abotev
I read all documentation which you have and I don't understand, how to assign UUI from  Remote Expert Mobile SDK to Finesse agent call variables.Could someone help me please?
Thank you in advance,
Angel
bcason
Hi, Angel. if you're using UCCE with CVP, you open OAMP and in your call server config, under the SIP section, you add a header to the SIP Header Passing config. The exact text (case sensitive) you want to add is "User-to-User". This will pass the value to the SIPHeader variable in ICM that you can access from your scripts.
Hi Bradley,
Is there any way to achieve this with UCCX even with a custom middleware?
Valentin
Hi Valentin, were you able to come up with a solution for this? Am looking to do the same
