Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi! I have a problem on CUCM 7.1.5 with EM authorization. Case:User logon on phone A with address B.JTAPI application starts and successfully adds observers on phone A and address B. Application receive events.User logoff from phone A.User logon on p...
gorbunov by Level 1
  • 2705 Views
  • 5 replies
  • 1 Helpful votes
Hello,I have TCL code which does db query and add the retrieved data to custom sip header.However we have found that during leg setup header gets truncated, i.e we do not get full data in header.As far as  I am aware max length of header is 256 chara...
AshG by Level 4
  • 703 Views
  • 3 replies
Hello,We have TCL script which does the DB query based on CLI and if DB query fails ( i.e. DB server is down or no record fund), TCL Script rejects the call.Now we want the TCL script to raise alert if DB query fails. Just wondering what is the best ...
AshG by Level 4
  • 591 Views
  • 1 replies
I have a call between to parties A and B.  B consults to a route point C.  Sometimes we get what jtapi events out of order.  We get CallCtlConnOfferedEv on the route point before we even get Held on the main call.We expect this order, more or less:Ca...
These are not much used but they are another thing on which the developer guide is wrong, page 5-13.First of all the codes format is ls_xxx, not ts_xxxThen, their meaning is not exactly as the manual says. From what I observed a typical sequence for ...
Resolved! Call Start Time
Is it possible to get a start time of a call using jtapi?(I understand that adding an observer, capturing call connected event, and then recording the time is one way, but is there a stored property somewhere where this is tracked?)
razaali20 by Level 1
  • 675 Views
  • 2 replies
Top Solution Authors
