Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi,I'm having problem where the application is not receiving ringing notification event. It is receiving OUT_OF_SERVICE and BACK_IN_SERVICE.ID   DN Num     Tag Mac          MRef CreateTime           #Msg==== ========== === ============ ==== =========...
tj1 by Level 1
  • 11262 Views
  • 14 replies
Resolved! tcl app error
Hello,We have created a simple tcl script to extract data from db server.if we run the script via tcl shell on cube it runs fine. However if we configure it as an application and apply to dial peer we get errorApplication drd in dial-peer 31 not foun...
AshG by Level 4
  • 1475 Views
  • 5 replies
Hello,I'm using Cisco's EpApi for sound stream handling for call management. Everything works ok. I can get the streams, start the streams, sound is coming and going. I have found in the documentation the EpStreamCodecInGet function and implemented t...
Would like to understand how to use CDR/CMR to determine the time a call spent on hold and if the call was abandoned by the far end while on hold ?
jeffande by Cisco Employee
  • 636 Views
  • 1 replies
Hi,I'm having an issue with a JTAPI application I'm building. The application reacts to an incoming connection to a listener on a CTI route point. I'm working with CUCM 8.6 and Cisco IP Communicator.The normal flow is: - User dials a directory number...
Smythtech by Level 1
  • 1853 Views
  • 4 replies
Resolved! Rtplib
Is there an sample code anywhere on how to use the Rtplib API to play an announcement?Thanks,Ben
bhoover02 by Level 1
  • 2786 Views
  • 11 replies
Hello,I have ran into the following problem:1. there is an active call between (A) and (B)2. (A) calls the lineHold function3. (A) receives a CallStateChange event, stating that the new Call state is Hold4. (B) doesn't get any call state change.What ...
I have two applications: A has opened line 1, B is monitoring line 1. If there is an incoming call on line 1, A will accept, than answers it. In case A crashes, can B take over the call, meaning continue somehow the conversation?
Top Solution Authors
