Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
My application attempts to call an extension from a CTI port. The call to lineMakeCall() is successful but I immediately get back a disconnect event with reason LINEDISCONNECTMODE_BADADDRESS. My function call looks like this:int nResult = lineMakeCal...
bhoover02 by Level 1
  • 684 Views
  • 1 replies
Hi Support,I have found pieces of information about this, but i am at the point where i need to ping you for an answer or for the link to the correct doc. However, i would much prefer if someone could clearly explain here...I have wrote an Applicatio...
Hi Support,Is there a limit to the number of devices a single TAPI application (using a single TSP) can receive Call Events for? I have completed an Application where i enumerate (open and monitor) all the Line devices assigned to my user in CUCM and...
Dear, I am using Cisco JTAPI to monitor extensions in Cisco UCM.I found strange bbehaviorof JTAPI while dialing from JTAPI monitored device.The call pattern must be like Offered->Dialling->Answered->Disconnected.Instead I am getting call events like ...
Dear All,I am not sure about this is correct forum for this query.All of us know that CTIManager sends information about CTI events.I want to change behavior of CTIManager so that CTIManager can send information about particular events only.Can we do...
Hi I have the scenario :1> User A , B and C ... etc are in conference call through cti terminal 2> User A makes call to external user say it as User D , this call should be a private call between User A and User D , 3> Once User D ready to join confe...
shahhuss by Level 1
  • 443 Views
  • 1 replies
In my TAPI application with CUCM 7.0.1 I need to place a call from some "virtual" extension that isn't associated with any actual phone to an actual extension, play a recording, and listen for DTMF. In other TAPI applications I have written I have us...
  • 1341 Views
  • 2 replies
Is there any documentation anywhere describing how Cisco TAPI Wave works other than just the API functions? Is there any example code?Thanks,Ben
  • 731 Views
  • 2 replies
I've successfully installed the Cisco TAPI Wave driver but when I make a call from a CTI port to an extension and call lineGetID() it fails with reason LINEERR_OPERATIONFAILED. This also fails when I try the same operation using the Microsoft TAPI Br...
  • 489 Views
  • 0 replies
Hi,I have this scenario:2 SCCP phones (A and C) and a Third-party SIP device (B)A calls B and B transfers to C, but when I attempt to transfer I receive the error "destination not found" on device (3cxPhone) and error 491: Request Pending, but if I m...
