Certified Remanufactured Equipment
Browse the Community
Activity in Certified Remanufactured Equipment
2960 x unable
hi need your expertise, i have 2960 x sw but i unable to receive netflow to my monitoring, hopefully you can help me   flow record my-recordmatch ipv4 protocolmatch ipv4 source addressmatch ipv4 destination addressmatch transport source-portmatch tra...
wan12 by Level 1
  • 4052 Views
  • 2 replies
CP-8831 Conference phone
It is important to keep all responses to apply only to the CP-8831 conference phone, no others. I have come to find that even though the 8831 is specifically designed to be a conference phone, it only allows 1 external call at any given time to be pa...
cdrobny by Level 1
  • 4640 Views
  • 0 replies
CERTIFICADO
Buen día, hace unos años, como parte de mis requisitos académicos, lleve un curso de CISCO, del cual deseo mi certificado, por favor indicarme los pasos a seguir o en caso contrario, enviarme el certificado correspondiente
TWO ISP one router dmvpn enabled
Dear Cisco Community,I need help on this issue.We have TWO ISP's with /30. However, we cannot make them equal, that is equal path to internet.  Should we remove default path to internet?Our router (Cisco 4431) reverts to the slowest ISP.Our objective...
EmnKadis by Level 1
  • 287 Views
  • 1 replies
vManage and vEdge
A while back at another company I worked for we had vManage and vEdge using ISR's, no Meraki, no Viptela.My current company is about to embark on a Meraki deployment. I'm wondering if this is similar to the vManage/vEdge environment I was once in, wh...
ronekvo1 by Level 1
  • 4385 Views
  • 1 replies
Top Experts - Last 30 Days
