802.1x and DNA
Leftz
Level 4
Level 4
Hi We can configure 802.1x to limit certain user pc to access to some sw port. But when the user move to another building, he cannot access network as the sw in the second building does not have configuration for him. Is it possible for DNA to be able to resolve the issue? Thanks
5 Replies 5
Preston Chilcote
Are you using ISE?  Usually ISE is responsible for pushing vlan configs down to switch ports in an 802.1x environment.  DNA plays no role, other than helping automate the dot1x config across your access switches.
Leftz
Level 4
Level 4
@Preston Chilcote  Thanks for your reply. user pc walk among different building and need to access network via access switch in different buildings. Without 802.1x config on switch port, administrator can control the user to access the network via DNA, ISE etc?
Preston Chilcote
You need 802.1x config to tell the access port that it needs to authenticate and authorize the user before granting access (it will then ask ISE).   Without it, the user will be given access to any port it plugs into.
Leftz
Level 4
Level 4
traditionally, its. we have to config 802.1x at access switch. so even if we use DNA and ISE, we still have to configure 802.1x on access switch as before?
Preston Chilcote
DNA can help you automate the configuration across all of your access devices by creating and provisioning day-n templates (or by building a full Software Defined Access fabric), but yes you still need 802.1x config on the interface.
If you want to learn more about how get the most from DNA, I recommend watching Cisco Live presentations or asking your Cisco Account Team to introduce you to a Cisco Customer Success Representative.
