9166D model missing from Catalyst Center
Wondering if anyone knows why the 9166D (directional) AP isn't showing as an option in Catalyst center, either for a model being added or in the heat maps for planning purposes?
I have been looking through the documentation, and also don't see a way of manually adding a model.
Found this on the AP Datasheet. Probably the version supported from 2.3.4.0 is the "I" model and the "D" model is not.
@michael.bungard1
Supported  on version 2.3.4.0 or newer. Which version is yours?
That is what is confusing me..... 2.3.5.6.
I found it in the compatibility matrix as well, it just isn't listed in either the PnP menu to pre provision devices, or in the Design area for planning on heatmaps.  Other Directional antennas are there (mostly older ones), and the 9166I is there, but not the D.
That makes sense, and I missed that.
Guess I am gonna have to push the upgrade button XD
Thank you for catching that!
