09-30-2024 01:53 PM - last edited on 09-30-2024 06:21 PM by shule
First discussion post...
Is there a way to create a template that can pull device information from switches in your environment? Not the switch that the template is being provisioned for.
I am trying to copy interface configs from an old switch to a new switch using CLI templates written in Jinja.
Any advice is very appreciated. Thank you in advance
10-01-2024 11:30 AM
No, but if you are upgrading from cat3k to 9300's you can use the Switch Refresh Workflow available in 2.3.7 code.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/catalyst-center/2-3-7/user_guide/b_cisco_catalyst_center_user_guide_237/m_dnac_workflows.html#switch-refresh-workflow
10-02-2024 02:19 PM
Thank you for the response.
The problem is that we have a lot of devices that are not supported through a Switch Refresh Workflow, like 3560s. We are upgrading our entire school district from our 3Ks to 9Ks so I am trying to find a streamline way to copy over port info without having to copy configs, modify and paste them manually
11-25-2024 04:07 AM
Did you find the answer for this? We have the same problem
