CatalystCenter DayN Template
LAN team
I was already using Day0 templates in PnP mode and I'm starting on DayN templates.
There is something that bothers me and I suppose I'm making a mistake somewhere.
I want to push a specific template for a piece of config, but when I use provisioning, CatalystCenter systematically pushes a part of generic network config inherited from "Network Settings", DNS, domain etc... and I don't know how to not push this part of config. I just want to push my template defined in the DayN project.
Thanks in advance.
Dan Rowe
You have several options:
1. Push the template using the 'Provision Template' option under Template Hub
2. Use the 'Provision Template' workflow under Catalyst Center menu -> Workflows -> Provision Templates:
3. Push the template using the Template Programmer API
Screenshot 2024-09-13 at 12.35.22 PM.pngAdam Radford create a script that utilizes the template programmer API to push templates to target network devices which you can use as a reference. Please note that this script does not support pushing templates that utilize variable binding or system variables:
https://github.com/CiscoDevNet/DNAC-TemplateProgrammer
The options above will only push the template configuration, network intent configuration does not get pushed during these workflows like they do when you execute a Day-N provisioning workflow.
HTH!
Dan Rowe
HTH!
