Showing results forĀ
Search instead forĀ
Did you mean:Ā
DNA-C 2.1.2.5 Template Editor using Jinja2 Templates
HUBERT RESCH
Level 3
Level 3
Hi all , with Velocity-Templates there was the possibility to add interactive or exec commands to the template which works fine.
Now customer wants to use Jinja2-Template, seems this MODE_ENABLE and INTERACTIVE is not possible there, is there another syntax to use it ??
Thx
Hubert
#MODE_ENABLE
#INTERACTIVE
mkdir flash:ARCHIVED-CONFIGS<IQ>Create directory<R>ARCHIVED-CONFIGS
#ENDS_INTERACTIVE
#ENDS_END_ENABLE
afekete73
Not a timely answer, but you may use event manager applet.
(I have just found this thread.)
