Cisco Champion Public Discussions
I’m trying to connect to Cisco Finesse via XMPP over BOSH using Jabberwerx.js. One agent account is able to connect successfully, but another agent (which uses a UPN-style username) fails with a SASL not-authorized error. Working Agent This agent is...
I already created subinterfaces, encapsulate, setup each ip address of terminals, the connection between switch and router is on trunk mode but I still can't ping other terminal with the same vlan on other switches(I can ping vlan 10 terminals on the...
cpdl2325 by Level 1
  • 1744 Views
  • 10 replies
hello guys kindly help me configure this two devices properlyi just want the calls to go throughProblem Statement:The current network topology involves a PBX with a static IP address (192.168.1.101) connected to a Cisco SG300 switch so are the IP pho...
We have installed cisco1532e on lightweight image and the user try to connect through the mobile with 2.4Ghz (mobile only connect 2.4. Ghz) but it does not connect and meanwhile when i connect my laptop with the same access point it connected with 5 ...
