UCS Blade Mgmt ips
In our environment there are 15 chassis with 8 blades on each its hard to find mgmt ips of blades.Can we pull this inventory using powertool?
nveda
Hi Vineeth,
1. For IP's coming out from management IP pool -
PS C:\> Get-UcsIpPool -Name ext-mgmt | Get-UcsIpPoolPooled | select Id, AssignedToDn
Id        AssignedToDn
10.65.183.11
10.65.183.12
10.65.183.13        sys/chassis-1/blade-2/mgmt/ipv4-pooled-addr
2. For static management IP -
PS C:\> Get-UcsVnicIpV4StaticAddr | select Addr, Dn
Addr        Dn
10.65.183.10        sys/chassis-1/blade-1/mgmt/ipv4-static-addr
Thank you,
Nitin
nveda
Hi Vineeth,
Id        AssignedToDn
10.65.183.11
10.65.183.12
Addr        Dn
Thank you,
Nitin
Thanks Nitin
This worked.
Cisco UCS X-Series Energy Efficiency Offer
