Cisco Developed UCS Integrations Knowledge Base
Field Notice 70545
Knowledge Base Articles
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develop...
rarausha by Cisco Employee
  • 72 Views
  • 0 comments
Cisco has released the 4.0(0) version of the Cisco UCS Manager VMware vSphere HTML remote client plugin. The UCS Manager vSphere HTML client plugin enables a virtualization administrator to view, manage, and monitor Cisco UCS physical infrastructure....
Reg.PNG Screen Shot 2018-09-28 at 4.14.11 PM.png Screen Shot 2018-09-28 at 4.15.00 PM.png Screen Shot 2018-09-28 at 4.16.19 PM.png
dsoper by Cisco Employee
  • 25233 Views
  • 25 comments
  • 6 Helpful votes
  • 138 Views
  • 0 comments
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC, Cisco UCS Common and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core m...
  • 316 Views
  • 0 comments
  • 386 Views
  • 0 comments
aapatwa by Cisco Employee
  • 277 Views
  • 0 comments
asagade by Cisco Employee
  • 518 Views
  • 0 comments
  • 346 Views
  • 0 comments
  • 574 Views
  • 0 comments
  • 465 Views
  • 0 comments
Cisco UCS PowerTool Suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC, and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool modules are developed using the ....
  • 763 Views
  • 0 comments
This script automates the upgrade of UCS Manager firmware (logging into CCO, downloading firmware bundles to a local working directory, uploading bundles to the target UCS System and walking through all steps of the upgrade, including creation/assign...
ericwill by Cisco Employee
  • 17653 Views
  • 23 comments
  • 6 Helpful votes
Purpose of script: This script collects metric count data from your ACI fabric using REST API calls and saves it to an Excel file on the local computer. It requires a CSV file as input, containing the IPs, usernames, passwords, and Fabric Names of th...
keytyler by Cisco Employee
  • 544 Views
  • 0 comments
  • 580 Views
  • 0 comments
Top Contributors
