Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develo...
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develop...
Howdy folks (by the way, there is no good 'label' for this question), I've got a Python script going out to many sites around the world to query both 'ComputeRackUnit' and 'ComputeBlade' class IDs. This is across everything from M2s (almost gone!) t...
Cisco UCS PowerTool Suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC, and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool modules are developed using the ...
This script automates the upgrade of UCS Manager firmware (logging into CCO, downloading firmware bundles to a local working directory, uploading bundles to the target UCS System and walking through all steps of the upgrade, including creation/assign...
Hi Team,one of our BL has exsi OS which is unresponsive, we able login to the KVM, but unable to login inside vSphere after entering the pwd, it's not going inside.Please suggest for any troubleshooting steps.
i have a ucs c220 working properly, but would like to access in cimc interface and i don't have the correct user and password. what is the best way to reset that?
Purpose of script: This script collects metric count data from your ACI fabric using REST API calls and saves it to an Excel file on the local computer. It requires a CSV file as input, containing the IPs, usernames, passwords, and Fabric Names of th...
UCS-Call-Home-Check.ps1By Paul CableAll the hard work was done by Martijn Smit <martijn@lostdomain.org> in his Cisco UCS Inventory Script.First Usage: .\UCS-Call-Home-Check.ps1 -GeneratePassword -This creates an xml file with the credentials, must be...
Cisco recently (late Dec '23) released the v3.0 Cisco HyperFlex Remote Plugin for VMware vCenter.Supported Cisco HyperFlex Release: 5.0(2a) and laterESXi 6.7 U3 and laterThis plugin is compatible with vSphere 8.0 (the previous plug-in version, 2.2, i...
Cisco has released the 4.0(0) version of the Cisco UCS Manager VMware vSphere HTML remote client plugin. The UCS Manager vSphere HTML client plugin enables a virtualization administrator to view, manage, and monitor Cisco UCS physical infrastructure...
I've been banging my head on this one for a few days. Deploying the UCS Manager Remote Plugin 4.0 for VMware vSphere, the OVA is deployed as expected. Network information and login are passed successfully. Confirmed VM network settings are correct...
