We have provisioned some of our existing wlc`s into DNA. And have had some problems around our voice setup. Our existing WLAN setup had CCKM enabled for old 7925 cisco iphones. However the CCKM option is nowhere to be found in DNA, so in order to get our phones on "air", we have to configure this on the WLC directly.
This is not a good solution, as DNA will sometimes change this back if you run a reprovision of the wlc, wich we have done regulary beeing in the middle of a migration proccess.
Is it possible to get CCKM enabled on the WLAN from DNA ?
