06-13-2020 02:54 PM
I have a pretty simple setup with a single 9300 Switch as C|B|E and configured 2 VNs on the device.
I am not trying to make a handoff towards a router but I cannot get the DNAC to bush the Border configuration to the device.
Every time I try it only gives me an error with:
Provisioning failed due to invalid parameter. The interface gigabitethernet1/0/24 on Device a6aa*******16 has an IP, remove the IP and then use the interface.
On interface Gi1/0/24 i have the following configuration and I have resynced the device:
interface GigabitEthernet1/0/24 device-tracking attach-policy IPDT_MAX_10 end
Any advise would be appreciated.
Solved! Go to Solution.
06-13-2020 03:27 PM
5 minuttes later everything worked.
06-13-2020 03:27 PM
06-13-2020 11:48 PM
06-14-2020 03:39 AM
Looks like logs are not configured per default?
Looks like you don't have any logging indices. Let's add some!
Or am I in the wrong place?
