Cisco Kinetic
Labels
Hello Please, I discovered Cisco Networking Academy not so long ago and signed up for the free classes. Even though programming is my aim, I started with IoT, and got to the point where I would create a simple network using packet tracer. I configure...
Khadkay by Level 1
  • 2868 Views
  • 4 replies
Hi,After an SD Card was created with PL-App Launcher on PC, I was trying to start up the OS on Raspberry Pi 3B. I  got the error "End Kernel panic - not syncing: No working init found. Try passing init= option to the kernel." Does anyone know how to ...
For a Kinetic-enabled IR809 router, port 500 (ISAKMP/IKE) and 4500 (IPSEC) are required to be opened for connecting to the U.S. cluster for GMM. What if port 500 and 4500 are already forwarded to the customer's VPN service? Is it possible for Kinetic...
Hi,    I have reserved an instance for cisco kinetic for cities it says active but not receiving password mail, but i see an error in activity (error:Cannot assign account, please raise a case in sandbox forum). Can you please help. https://devnetsan...
jtsubram by Cisco Employee
  • 1947 Views
  • 1 replies
Greetings, I've tried this lab several times and it's always failing at the same point. I'm using Chrome, have a VPN connection and the instance is up. I'm following the lab step by step:1) Create DataFlow2) Aggregate & Transform I Added CPU_Usage an...
rmongeon by Level 1
  • 5534 Views
  • 7 replies
So I started up the "Create a Dataflow in Cisco Kinetic EFM" lab. I'm able to ping the EFM host (10.10.20.22). I can SSH to it. I can't get the web GUI to come up. I used both Firefox and Chrome and have told those browsers that the site is safe. I'm...
rmongeon by Level 1
  • 2730 Views
  • 2 replies
I have IR829 (15.8(3)M1) with IoX (1.7.0.7) and deployed EFM 1.6 app. When I create a new dataflow:I don't see any values in any tableI'm unable to import or export dataflowOlder version without C++ broker work fine. Do you know possible cause of the...
dsoukup by Level 1
  • 6053 Views
  • 5 replies
Hi there, did one of you ever get the OPC link up and running?Currently my small demo consists of a EFM 1.5 installed locally on Windows and a simulated OPC-UA server running on a separate Windows machine.The documentation on github describes the fol...
Unanswered Topics
