Hey all! I am trying to host the TIG stack on my personal laptop so I can collect and store Netconf data from a network I will be building in the reserved CML instance. However, I am having some problems being able to connect to my personal laptop. ...
I am trying to find a good example or lesson on configurating TLOC extensions utilizing the Configuration Groups (Not classic templates) and the C8000v. You can use the guided tour when using Configuration Groups and enable TLOC extensions there, b...
Hello CML community! I'm using CML to build all kinds of demos. I’ve successfully onboarded virtual Catalyst 9k switches via PNP into Catalyst Center and was able to build 802.1X and TrustSec labs, nice! However, there's one thing that’s been frus...
Hi there, I am James Zesinger and I work for Corvid Technologies. We use some of your products for a project of ours, and I was wondering if you had a SolidWorks model of the product? We use your Cisco Catalyst 9300 Series Switches (C9300-24T-E). Tha...
I'm looking at taking Cisco's ENCOR E-learning. Does it Use CML? I don't have a computer that can run CML at this time and I would like to know if anyone here has taken/ran the course. Will I need my own computer or will lab environments be provided?...
Good day folks! Maybe someone can help me thinking about this issue Just created my first CML (2.5) lab .. got a bunch of Nexus9000v up and wanted to reach their mgmt0 interface from another VM in out vSphere Setup, where also the CML VM is running....
I am trying to download to the CML-Free .iso and .ova files but unable to do so.Whenever i try to dowload, it gives the below message, even though i have already added the address in my profile-Thank you for registering with Cisco.com. In order to co...
I only download at home laptop to tryNot on behalf of company But it pop up message require to fill company address I am not SI company and afraid fill in address become partner account and lose ownership of exam certificates
I have VT-d on my laptop and not VT-x. Is there no way for me to use CML?I got two errors in KVM/VMX and with images. I've searched google and nothing has helped me. Has anyone run into this issue? I'm using VMware and the image for VMware. Any thoug...
I understand that vEdge and vBond are basically the same device. And depending on if the command 'vbond <IP> local' dictates whether the device runs as an vBond or a vEdge. When trying to use it as an edge device. I am unable to set the encapsula...
Hi, we have deployed CML 2.8 on baremetal and are hoping there is a way to adjust the system memory utilisation limit of 80%? Our server has 256GB of RAM and an 80% limit on large servers is quite a waste. We were hoping to be able to run at least a ...
Juniper has the qcow2 image files and I am looking to get them made into image def and custom nodes. I can get it setup but not boot, I am assuming something is not right with it and there is obviously no documentation on this setup.Has anything gott...
Hello Team,I am facing below issues in the CML, could anyone assist please.I have launched CML free tier with help os vm ware workstation pro, but inside the CML dashboard, I am seeing KVM/VMX is not ready in the system status panel.Other thing is If...
Hi AllI am trying to install CML 2.8 on a HP Proliant DL380 G6 and get an error during the 'running early commands' just after the 'running chvt 1'.The response is 'An error occurred. Press enter to start a shell'.Regards in advanceJohn
Hi,I’m using CML 2.8.1 Personal and have deployed SD-WAN version 20.15.1. However, I’m encountering an issue where I can’t execute a specific command on vEdge 20.15.1. Despite successfully installing the root certificate, the error persists. I’ve als...
