Cisco PSU (PS-2651-1-LF)
arcon99
Hi All
How do I power on the 12v rail on that PSU.
I can't find the pinout for it. Does anyone know, or is it controlled by PMBus?
B.R.
Soichiro-Ono
Hello.
If it's a product made by Cisco and supported by Cisco, it can be installed in UCS without any problems, so I don't think you have to worry about that. Best to contact the place of purchase.
Regard,
If you found this post helpful, please give it Helphul.
If my answer solved your problem, click "accept as solution" so that others can benefit from it.
有用な回答だと思われる際には いいね! をクリックして頂けると幸いです。
回答があなたの問題を解決した場合、解決済みをクリックしてください。
arcon99
Thanks for the reply
I am not using it in a cisco system. just want to use it as a powersupply like the common slot HP psu's, I have tried cisco support but it is useless.
