Code Exchange
Ask questions about your Developer Code Exchange submissions
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
hi engineers i have an issue with cat 9300 i have 9300 as core and downlink connected 3 cat 1300 all are with trunking ports , i have 5 vlans on core as following 192.168.1.0, 2.0, 3.0, 4.0, 5.0each vlan have users but they are not able to ping each ...
Resolved! vManage API
Has anyone had success in calling generate bootstrap API ​/system​/device​/bootstrap​/download​/{id} ?
OCT by Level 1
  • 1251 Views
  • 8 replies
Hello,When running the attached script, I am running in the following issues:response = requests.get(ip + dn, headers=headers, auth=auth, verify=false)NameError: name 'headers' is not definedDuring handling of the above exception, another exception o...
Netmart by Level 3
  • 320 Views
  • 1 replies
From today, DevNet users can rate Code Exchange repositories.This rating can help our authors and Code Exchange engine detect projects that enjoy communities. It also identifies possible improvements or issues of related source code.Find a related Co...
Oleksii_ by Cisco Employee
  • 504 Views
  • 0 replies
  • 1 Helpful votes
Hello,I am working with NETCONF/RESTCONF and MDT (TIG Stack) on the IOS XE on Cat8kv reservable sandbox.  I have not been able to figure out how to stream interface state via on-change.  For reference, I am using the basic ietf-interfaces.yang model....
slarrarte by Level 1
  • 1893 Views
  • 7 replies
Hello,I am trying to run this simplified  testbed file and receive the following issue:Also if you could please advise on the platform value required in testbed.yaml file when using cat4500.PID: WS-C4507R+E$ python3 pyATSTEST.pyTraceback (most recent...
netmart2 by Level 1
  • 1108 Views
  • 1 replies
HelloI tried the following Ansible playbook, the goal is to change the ip helper address of an existing vlan interface.And I am receiving the following error: TASK [Changing IP Helper Address] *********************************************************...
Netmart by Level 3
  • 1024 Views
  • 2 replies
Hello,I was wondering, whether it is possible to pull also the IP address in addition to hostname, pltaformID, sofwareType, and Version Excerpt URL:dnac = {        "host": host,        "port": 443,        "username": username,        "password": pass...
Netmart by Level 3
  • 696 Views
  • 1 replies
I am trying to configure Terraform and Intersight and trying to call the OS Install workflow, but something isnt right.  I ran terraform init, then plan, then apply, but I get this error message below.  Any idea what could be wrong? intersight_os_ins...
Tbowden by Level 1
  • 2818 Views
  • 13 replies
Hello,When Ansible is trying to connect to host [Cisco Cat 6, the following error message appears:[WARNING]: sftp transfer mechanism failed on [172.16.1.1]. Use ANSIBLE_DEBUG=1 to see detailed information Below you will find an extract of debug log:2...
Netmart by Level 3
  • 1698 Views
  • 3 replies
Unanswered Topics
