Meddane
I released my book Dial Plan and Call Routing Demystified On Cisco Collaboration Technologies with additional and atypical scenarios.
Lab 1: Translation Pattern for inter-site dialing
Lab 2: Translation Pattern to block international calls
Lab 3: Translation Pattern for Overlapping Numbers
Lab 4: Translation Pattern to Match the Calling Number
Lab 5: Originator’ s CSS in Translation Pattern
Lab 6: Call Routing using Standard Local Route Group
Lab 7: Digit manipulation of Calling Party
Lab 8: Globalization Dial Plan on CUCM
Lab 9: Globalization of Emergency Number
Lab 10: Traditional SRST Call Manager Fallback
Lab 11: Enhanced SRST CME-Based
Lab 12: Region and Call Admission Control
Lab 13: Automated Alternate Routing AAR
Lab 14: AAR with Globalized Call Routing
Lab 15: Device Mobility Without Globalized Call Routing
Lab 16: Device Mobility With Globalized Call Routing
Lab 17: Toll Fraud With CUCM and Unity Connection
Lab 18: Toll Fraud With OffNet to OffNet Transfer
Lab 19: Globalized Call Routing With Multisite Deployment
Lab 20: Tail End Hop OFF TEHO With Globalized Call Routing
Lab 21: H.323 Signaling Protocol With Wireshark
Lab 22: Firewall Traversal, NAT Traversal and MRA On Cisco Expressway
Lab 23: Auto Attendant On Cisco Unity Connection
Lab 24: Cisco Unified Border Element CUBE Diversion Header
Lab 25: Cisco CUBE Dial Plan for PSTN Calling With Webex Calling
Lab 26: Extend and Connect With Cisco Jabber Lab 27: Conference Now Feature On CUCM
Lab 28: AdHoc Conference Bridge
Lab 29: Designing Dial Plan with Separate CUCM Cluster and Single CMS Cluster
Lab 30: Designing Dial Plan With Cisco Session Management Edition for Conferencing
Lab 31: Designing and Implementing Globalized Dial Plan
Appendix A: Route Pattern Translation Pattern Transformation Pattern order priority
Appendix B: Closest-Match Routing
Appendix C: Digits Manipulation on Cisco CUCM, Where and When to do it?
Appendix Calling Transformation Pattern at the Phone Level
Appendix E: SIP Method for Transfer Type: Release to Switch VS Supervise Transfer
Appendix F: Accept Unsolicited Notification and Accept Replaces Header
Appendix G: Transformation Pattern use case
Appendix H: Run on all active unified CM Nodes option on SIP Trunk and Roue List
https://www.amazon.com/Routing-Demystified-Cisco-Collaboration-Technologies-ebook/dp/B09Z39LD9R/ref=tmm_kin_swatch_0?_encoding=UTF8&qid=1688114377&sr=8-1
