cdnadmin
Community Member
This document was generated from CDN thread
Created by: Ashish Mishra on 09-11-2010 04:53:36 PM
I'm from CUOM team and we use JTAPI for troubleshooting IP phone features in our product.
For current release we have a requirement for extension mobility, where I need to perform EM login/logout to test the EM service.
While going through the JTAPI developers guide, all I found is the following:
Extension Mobility Username Login
The Extension Mobility Login Username
enables applications to get the Extension Mobility login username from the API
provided on CiscoTerminal. Use getEMLoginUsername() This method returns the Extension Mobility login username. If
no EM username has logged into Terminal, this interface returns a null or empty
string.
Is it also possible to login to EM service enabled in a phone using JTAPI ?
Subject: RE: JTAPI for extension mobility
Replied by: Mohan Potluri on 09-11-2010 05:45:42 PM
No.
Cisco JTAPI doesn't have any API to do EM login.
User need to manually login or use other API (search for 'CUCM EM API' on cisco.com)
Replied by: David Staudt on 09-11-2010 06:48:27 PM
The AXL admin SOAP API can do logins, as well as the dedicated (simpler) Extension Mobility API Mohan refers to.
