kavle
we want to route the call to Third party vendor over PSTN during off hours from UCCE script.
how to do that routing.
any example script provided would be great
zarifaz
Hay Kavle
There are many ways to forward / send / route call from UCCE script to external part / number, i am assuming you are not using admin script and getting Day of week and time checked within routing script if so here are the steps:
let say you if you already have Day of Week object in routing and time checks then you just need to add another Label Object and mention number (on which you want to foward call) by selecting Dynamic option and mentioned number in quote for example "0044345xxxxx" here in this example 0044 for UK and then number. reffer to below screen
"LIKE" if it helps
