scotthan
This is a great addition to any dorm room or cubicle . Gives you a quick view of all the UCS hardware. When you are talking up UCS in your office you can simply point. This is also available delivered to you in a real poster for a nominal charge of $3 -> https://cisco.mediuscorp.com/market/cisco/productView.se.work?/nxt/rcrs/proieidentity/=19882
This is Side 1 - check for the other document that is Side 2
shine pothen
Level 3
Level 3
thanks for sharing this Poster All in One
