Delivery Collaboration Portal (DCP2) External Knowledge Base
Knowledge Base Articles
  Previous ArticleNext Article  Occasionally as a Cisco customer or partner, you might be asked to provide comments on a document in the review stage. You will then be invited on a discussion of a document. How to provide your comments on a discussi...
ptops by Level 4
  • 588 Views
  • 0 comments
  Previous ArticleNext Article  To edit the full properties of a document,  you should use the Properties pane that will show all properties applicable to a document. The shortcut to only edit the essential properties of a document is explained in p...
ptops by Level 4
  • 706 Views
  • 0 comments
  Previous ArticleNext Article  Once you have uploaded one or more documents, you need to verify and update some essential properties. Proper tagging is important for quality and ease of traceability of documents. Similarly, if you are defined as th...
ptops by Level 4
  • 591 Views
  • 0 comments
Top Contributors
