DevSecOps Defined Where We Are Now We can all be grateful for the recent developments in cybersecurity involving observability and AI, which have increased visibility and granular control, thus greatly improving threat detection and response. T...
In conversations about artificial intelligence (AI) and machine learning (ML), the terms ML model and ML algorithm are often used interchangeably. However, they refer to different concepts in the context of machine learning. ML Algorithm An ...
If you've ever accidentally removed files or folders with "rm", you know that your options for recovering them are extremely limited. In order to avoid that, you can set an alias so that when you use the "rm" command, it sends the files or folders co...
Call For Contributors (Technical/Non-Technical)GitHub Link: https://github.com/olasupo/bubbln_network-automationBubbln architecture and interaction with networks, ChatGPT and usersNetwork automation has become a cornerstone of modern networking, offe...
Network Automation Basics Automate Shell Scripts with Expect I remember in my early days of network engineering when I had a checklist that required me to SSH and Telnet into several servers and check the status or configurations to make sure every...
This is Part 2 of the Extremely Cool Command Line Tools - Supercharged with Rust series. For Part 1, see Extremely Cool Command Line Tools - Supercharged with Rust - {Part 1} Skilled network engineers, developers, system admins, etc. use Unix/Linux c...
The purpose of this document is to provide a smooth and quick, easy start for newcomers to SD-WAN vManage API. If you are not familiar with REST APIs, you can learn about them in the "Coding & APIs - Fundamentals" section. To proceed, we kindly reque...
Cisco Cyber Vision ensures continuity, resilience and safety for your Industrial Internet of Things (IIoT) technologies and industrial operations. Cyber Vision gives you visibility in remote industrial assets and their vulnerabilities, which @Geevarg...
In this article, I am going to guide you through the steps I take to set up my MacBook for software development. I will discuss some of the settings I change in macOS, as well as the software development tools I install and use every day for Python a...
There are many authentication methods used by RESTful APIs, but we can generally categorize them into two types based on how credentials are presented in the programming code. Basic authentication – credentials are presented using plain text Token-b...
The Cisco IE3100 Rugged Series Switches allow you to deploy in tight spaces and build robust fully managed industrial networks without sacrificing speed, security, or resiliency. Learn how the compact, gigabit ethernet Catalyst IE3100 Rugged Series s...
Skilled network engineers, developers, system admins, etc. use Unix/Linux commands line tools/utilities such as …. cat, ls, man, ps, etc.. Most of these were originally written for Unix or Unix-like operating systems, have been around for decades a...
While you are working on the Panoptica UI, have you noticed there are Panoptica CLIs?The URL for the CLI documentation is here. Panoptica CLI can do things like:• Scans Docker images for Known vulnerabilities• CIS Benchmarks• Detect exposed keys/pass...
The Common Security Advisory Framework (CSAF) is a standard used to disclosed security vulnerabilities in a machine-readable format that allows software and hardware producers (as well as their customers) to automate vulnerability assessment. CSAF su...
XML, JSON and YAML are the most popular data serialization languages. This means we use them to represent data structures and values, which enables data storage, transfer and distribution, often for use in configurations. XML stands for “eXten...
