DevNet Networking
Engage with peers and Cisco experts about networking developer tools and resources.
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Browse the Community
Crosswork Automation Hub
Welcome to the Automation Hub—a collaborative space designed for the automation community to foster ...
Controllers
Community space to connect, share knowledge, and seek guidance on network controllers and related to...
Network Devices
Explore, inquire, and collaborate on network devices.
Activity in DevNet Networking
Select NED for service
I'm defining a service that request feature on a NED available only for selected NED version.If I define the template as usual I got erro at load-time:reload-result { package snfeSERVICE result false info snfeSERVICE-SNMP-template.xml:109 Element: 'p...
Fantolino by Level 1
  • 206 Views
  • 5 replies
Question about conflict detection
Hi,I am hoping to get some guidance on conflict detection. We are running NSO 6.3.1.I have created one complex service that does builds the interface for customer services. It does a lot of work, it has a lengthy xml template and implements logic in ...
authentication error between Ansible and Nexus 9k
Hi all;I posted my question on a community I found for automation, But now I came across this dedicated DevNet automation. I Don't know maybe here is the right place to ask my question, but I'm not going to copy/paste the same stuff here. So I apprec...
How do we get access to Cisco MASA (for SZTP)?
Recently I watched one of the Wednesday live Cisco DevNet videos streamed on YouTube - this one was over Secure Zero Touch Provisioning. While familiar with ZTP, I had not previously heard of SZTP - it's purpose and functionality is very straightforw...
Automate identity certificate import on Cisco IOS XE
I've been struggling to automate the import of the identity certificate on a Cisco IOS device (specifically 8000V) using an Ansible playbook.  I run into 1 of 2 problems:1. Using the cisco ios_config module, the task will timeout after issuing the cr...
Resolved! PyATS: Connection failure due to hostkey missmatch
Hello, How do I handle these connection issues in PyATS?(.venv) [an144a@DEVAUTOS02 tests]$ python3 Python 3.9.16 (main, Sep 12 2023, 00:00:00) [GCC 11.3.1 20221121 (Red Hat 11.3.1-4)] on linux Type "help", "copyright", "credits" or "license" for mor...
Exablaze exanic x4 firmware
Does anyone know if it is hiding somewhere, or how to get some updated firmware for the old Exanic x4 SmartNIC? It doesnt look like it was ever given a cisco name like the Cisco Nexus SmartNIC K35-S (x10). It looks like there was an update in 2017 an...
GoPreaux by Level 1
  • 99 Views
  • 0 replies
Guestshell - IOS XE 17.09.03a - import cli Illegal instruction
Hi community , I hope you are doing great.After spending a good time reading and doing some troubleshooting I have decided to ask for some same.I setup guestshell in order to run python using eem. I am getting the following error : router-lab#more  b...
c-lopez78 by Level 1
  • 146 Views
  • 0 replies
NCS drop config false deviate replace
Hi,I'm trying to build a ned using NSO 6.4, but compilation is failing due to my deviation file.From devel.log, I have this error:  ncs progress usid=35 tid=1084 datastore=running context=cli trace-id=d5aafe3da82cf16c52206216ecfb575b output: augmente...
Top Experts - Last 30 Days
