DevNet Observability
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Browse the Community
Observability Blogs
Share your questions, use cases, and knowledge around observability and monitoring.
Activity in DevNet Observability
Tales From The Crypt: ODD Chapter 1
Observability-Driven Development (ODD) is the latest buzz phrase. One of the goals of ODD is to integrate observability measures into your code. Here's what could be the world's simplest sample, which makes it possible to identify the very line of co...
npetrele by Cisco Employee
  • 538 Views
  • 0 replies
AppDynamics DB Agent Collector Issue
Hi,  I am having a little issue while setting up the DB agent collector, it says to choose Agent. The labs says to select DBMon-Lab-Agent but there is no such option and only default database agent is showing, due to which I'm not able to connect the...
ThousandEyes Trek: The Motion Picture
This content is also published as a blog here. WARNING: Suffer through the 1979 Star Trek: The Motion Picture, the worst Star Trek movie ever made to make sense of what follows. Kirk: “Captain’s log, star date 2. There’s a really big thing out there ...
  • 774 Views
  • 0 replies
How would you use the ThousandEyes API?
I have a blog post on how I used ThousandEyes to see how well an Amateur Radio application called EchoLink can work. As I say in the blog, the best application of ThousandEyes would be to spot problems, especially with cloud services. If you offer a ...
  • 671 Views
  • 0 replies
  • 5 Helpful votes
Share your Expertise
Level up by answering questions in your area of expertise.
