Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Hi,We have a customer that has just upgraded to UCCX 15 SU1 and TCP Port 12028 no longer exposed therefore our integration can no longer connect to UCCX CTI APICisco TAC reporting that TCP port 12028 no longer exposed publicly, this appears to be a r...
Hello,We are using with OCI-P over TCP (not over SOAP) when using secured TCP we can use LoginRequest22V5 with the password in plain text.But when ot seciured TCP our code is still using AuthenticationRequest + LoginRequest14sp4 to have an encrypted ...
Manitoba is also affected by the new time change to permanent DST, now always offset -5https://news.gov.mb.ca/news/?archive=&item=75397Current work around is setting time manually to -5.
Hello,We connected Y-cable to DVI-I input of SX20 that splits the DVI-I input to DVI and VGA ports.When we connect a laptop with VGA output to the SX20 TC6.3.0 through the Y-cable, we have two issues:1) The PC does not detect what "monitor" is connec...
Would like to know if there is support for architecture arm 64, because there is an information of the apple we only have to submit applications with the arm64 architecture, follows:Starting February 1, 2015, new iOS apps uploaded to the App Store mu...
Hello, I am am a doing quite a lot of macros using the xapi, but I am confused with what exactly is the jsxapi libraryThis is stated int the help :XAPI integration in macros use the jsxapi library.How am I supposed to use this library?Thanks
hi,wondering where to download the android jabber guest client?i tried to search in google play store.but, there is not such app existed.however, i can find iOS version in iOS app store.please let me know where i can get the apkyoursAlan
Hi,Trying to request certificates via API.CSR create works only it does not use the altNames list.Also when using multi-server as distribution, it returns a error "Invalid Distribution!".and i mis the option to include the OU. like via the webpage.I...
This document was generated from CDN thread Created by: Malik Ehtasham on 26-08-2013 07:36:00 AM Hello Everyone,When an IVR Application is trying to access a audio file which is not available on the desire media server, then VXML server throws bad fe...
Pretty straightforward, looking to change the "Your Current Options" text on the bottom of the phone manually with a file, but I don't know how to do that, yes, I'm looking to do it CME style, but with a FreePBX system, I have a Windows 2K IIS server...
Apologies if this is the wrong board to be posting in... I decided to dabble a bit more into my hobby of IP Phones, and I decided I wanted to try getting FreePBX to host Cisco services using the SDK, fast forward to the relevant issue, meaning today,...
Hi,Looks to be a bug in XBusyLampField in 11.5 AXL.The schema is: <xsd:complexType name="XBusyLampField"> <xsd:sequence minOccurs="0"> <xsd:element maxOccurs="1" minOccurs="1" name="blfDest" type="xsd:string"> <xsd...
Dear Cisco Community,I hope you are doing well.I am currently working on a Cisco Room Kit EQ deployment and would like to implement custom controls on the touch panel using UI Extensions and macros. I would appreciate your guidance and best practices...
This document was generated from CDN thread Created by: Mayank Sharma on 12-01-2009 03:56:36 PM Hi again,Is there a way to access the device information like Serial Numbers? I could not find any table that stores that.I am using CUCM 6.1.Thanks,MaxSu...
Deploying a contact center solution with a customer requirement that on every outbound call made by their agents, they would like the called party to immediately hear a message as soon as they answer. For example, “This is ACME calling. This call may...
