CML bridge mode for subnet other than CML SUBNET range
akshayj2097
I am using CML with external connector in bridge mode. I am able to connect outside network when my virtual device ip is in the same subnet of CML server. But I want to configure devices which are on different network and connect them with my network. So how it can be done? what are the commands to connect internal topology devices to outside network? Please help.
Alex Stevenson
Hi @akshayj2097,
The documentation I found for how to do this seems relatively old but may still be helpful.
External Connectivity in Cisco Modeling Labs
https://www.cisco.com/c/en/us/td/docs/cloud_services/cisco_modeling_labs/v100/configuration/guide/b_cml_user_guide/b_cml_user_guide_chapter_0111.pdf
I also found this external video, which may be helpful.
Cisco CML External Connectivity | Cisco CCNA 200-301
https://www.youtube.com/watch?v=jk_0T3ge50c
See the section 'Game plan for connectivity, routing, and NAT', beginning at 20:00.
I hope this helps!
Ruben Cocheno
@akshayj2097
Just following up on this and see if you still need help?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
