Sandbox is currently down for Maintenance.
abzar
Can't spin a CML instance as it is showing Sandbox is currently down for maintenance. What's the time frame for this maintenance window?
@abzar team do not normally post times as there is no SLA with the sandbox and often the maintenance is unplanned and the team are dealing with an issue. Check back in the next day. If you have access to Cisco dCloud you can lab there.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
