Resolved! Cybersecurity LabVM Worksation 20230210
My VM keeps aborting in the oracle virtual box. Lab 4.2.7 of Cybersecurity essentials
Hello,I am new to Cisco IOx and I am trying to run a Helloworld app on a Cisco IR1101 router with Cisco IOS XE Software, Version 17.03.01.I am following the information and using the files from a guide on github: https://github.com/etychon/iox-aarch6...
Welcome to the Edge Computing Infrastructure community forum. We'll be talking about all things IOx here. Please post your questions, use cases, stories, and best practices!
Hello, experts!I'd like to test IOx application on Cisco ISR 4k, but faced a problem while generating IOx app with ioxclient from Cisco.The test stand is like this: VM with installed docker and ioxclient. Docker successfully downloads the images from...
Hi, everyone. I can generate, deploy, activate and run the my own Docker type C based application on the IR-1101, and this application works correctly using the IP protocol. But a requirement of this application is to run a GOOSE subscriber to receiv...
Hello,is there a way to pre-populate the /data partition with files while building the app bundle? I'd like to put a configuration file there or client certificates to authenticate and/or authorize the app with a remote server and be able to modify t...
Hello community,I'm encountering an issue while trying to run an RS485 Modbus RTU script on a Cisco IR1835 router. The script is designed to collect flow sensor data and send it to Azure IoT Hub. I'm hoping someone can help me troubleshoot this probl...
Trying to use Local manager to deploy/manage apps on a IR1835, however after logging in, I'm not given the option to configure anything. This screenshot is from the link: https://www.cisco.com/c/en/us/td/docs/routers/access/IR1800/software/b-cisco-ir...
Hi All, Just wondering, has anyone ever come across this message? Application Deployment Failed: Package signature file package.cert or package.sign not found in packageTrying to deploy a C Based Application on my IR829.
After upgrading my dev IR829 to 15.8. I'm no longer able to access the IOx local manager @ XXX.XXX.XXX.XXX:8443Did something change from 15.7 to 15.8? My applications are still working on ports 1880 and 8000 but not the IOx local manager.
I have my app loaded in FogD. FogD does have connectivity to the 1835 because it will load the device log from within FogD (Devices. > select device > View Device Logs). When trying to push the image to the 2 IR1835 I have, this is the error I receiv...
Since this happened to me, I thought I should share this.Messages like this appear constantly:*Feb 11 09:34:24.861: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failedThis is explained here:The user r...
Hey,I have a catalyst 8300 router and I upgraded the code from 17.09.04a to 17.13.1a. Now my ubuntu kvm virtual service will not activate. I've uninstalled and attempted to reinstall the ova file, i even tried an earlier version i created that i kn...
Dear Community, We have a large project on defense customers regarding IOx resources. We would like to make first sizing with IOx resources in such platforms as the following like : https://developer.cisco.com/docs/iox/#!platform-support-matrix/ent...
Good afternoon, everyone! I have this application running on an IR829. I have some problems, I would like to know if you have already gone through this and if you can help me. 1 - I need to write the logs to the environment variable. So that I can de...
Subject | Author | Posted |
05-15-2024 11:00 AM | ||
01-27-2024 01:21 AM | ||
12-13-2023 07:04 AM | ||
10-18-2023 03:33 AM | ||
08-27-2021 05:08 AM |
