General Internet of Things (IoT) Discussions
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
I was going through the following IoT learning labCisco DevNet Learning LabsIn Step 11, following link is provided from where the application can be downloaded.http://cs.co/deviotWhen visited the above link, it says "The content of this page is block...
I developed a POE lighting control board using TPS2379 and an esp32. It's worked on all of my other non-Cisco switches, but when I plug it in to 2 separate WS-C2960X-48FPS-L switches, I get nothing, not even a log entry. Other POE devices work, and I...
Hello,I am currently taking the "Introduction to IoT and Digital Transformation" free course at Cisco Networking Academy at skillsforall.comI am stuck on Module 2, 2.1.7, question 3 (image attached):I have to pick the correct answers on the black box...
lwmar by Level 1
  • 4373 Views
  • 5 replies
Background Concepts   LoRa (from “long range”) is a popular radio communication technique used in Internet of Things (IoT) solutions. LoRa is based on spread spectrum modulation techniques derived from chirp spread spectrum (CSS) technology. LoRaWAN ...
Hi, I am publishing data to MQTT broker in Kinetic from my laptop using a python code. According to my code each second, a new record publish to MQTT broker. But when I add the dataset to the dataflow and a json parser, it records only shows one reco...
