Cisco CSR1KV / 8KV and Filter support with NETCONF
m.rotteveel
Hello everyone,
I have a question about the support of the netconf specification on two specific virtual routers :
Catalyst 8000V - Cisco IOS XE Software, Version 17.04.01a
Cloud Services Router 1000V - Cisco IOS XE Software, Version 16.09.05
In my lab setup I tried to pass a "filter" to a get-config netconf request:
(using python, ncclient, also tried with yangsuite, same result)
<filter>
<native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native" />
</filter>
Using the exact same python script, where I just changed the ip address from one router to another,
the 8000V returns an "unknown element" while the 1000V neatly does what it's supposed to.
As far as I understand "filter" is not a "capability" but an integral part of NETCONF.
I can only conclude that not every device adheres to the full netconf specification.
My questions :
1) is my conclusion correct?
2) Is there somewhere to find which devices / iOS versions support which netconf components and which do not?
m.rotteveel
Just a fast reply, i must do more research. But the problem is NOT the devices. Its somehow ncclient.
this is what is outputs to both devices :
<rpc xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="urn:uuid:9b78d885-6adb-463e-93df-4533534873b3">
    <get-config>
        <source>
            <running />
        </source>
        <filter>
        </filter>
    </get-config>
</rpc>
The 1Kv accepts this fine, the 8kv doesn't.
The problem is this little thingy:
":nc" (in the rpc tag).
will followup if i understand whats happening !
@m.rotteveel simular to https://community.cisco.com/t5/other-networking-subjects/attributeerror-rpcreply-object-has-no-attribute-data-ele/m-p/4560220 maybe?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
