IP Telephony and Phones
Labels
We have an issue where our system is out of compliance due to one account being an enhanced plus account when we shouldn't have any. Two phones are assigned to the problem user, but when I try to remove one of the phones to anonymous or another user ...
pstibich by Level 1
  • 272 Views
  • 6 replies
My customer has CUCM ver 11.5 and I need to add several new Translation Patterns (TPs). From BULK there is not an option to add/update TPs. So I understand the procedure is this on ( I appreciate ANY correction or answers from doubts) I will  EXPORT ...
Hi We have a customer where we have this error: log4j:ERROR Failed to flush writerAnd we see:Disk/active 14154188K 1177904K 12814772K (92%)Disk/inactive 14154188K 899256K 13093420K (94%)Disk/logging 49573456K 0K 49557072K (100%)So the problem is with...
I have a CUCM version 15.0.1.11900-2  I have two 8861 wireless phones. They work calling everywhere inside to a lan connected phone, outside to the PSTN but if you call between the two 8861 wireless devices there is NO audio. Codecs look fine , hold ...
miket by Level 5
  • 199 Views
  • 4 replies
On CUCM version 11.5 the internal numbers use 4 digits ( XXXX) and they belong to partition "PTinternal". We need calls transferred from UNITY Auto Attendant to range from 7701 to 7799 go directly to their voice mail (without ringing) ONLY from 9:30a...
Resolved! Translation Rule
Good Morning/Afternoon AllJust need help with translation rule. I will need to translate number coming in from PSTN to a 5-digit number internally starting 8xxxxPSTN number- +44..........Translated to 5-digit internal extension  - 8....Does the below...
ece466 by Level 1
  • 470 Views
  • 16 replies
