IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6048 Views
  • 14 replies
Hello, i have a CME, the router has 4 FXO ports,each port connect to the PSTN they are under a common trunk group called BRC, when i make an outgoing call the call takes the first port, but if i disconnect the line from the first fxo port the call c...
we have an issue with SNR where there is no ringback when the Remote Destination (cell phone) is ringing. Once the call connects, the audio is fine. The cell phone rings, but the caller does not hear ringback.Here is the call flow:PSTN --> CMM (H32...
degg by Level 1
  • 1130 Views
  • 6 replies
Resolved! MGCP PRI
I am trying to bring up 3 pri's (new install) and I am receiving this when I debug "isdn q921" *Feb 11 14:17:24 MST: ISDN Se0/0/0:23 Q921: S4_SABME: BACKHAULED & vsc_wants_L2_up = FALSEIDEAS? I have verified pri switch type
dvanzee by Level 2
  • 2161 Views
  • 3 replies
Event Type: ErrorEvent Source: Cisco CallManagerEvent Category: NoneEvent ID: 3Date: 2/11/2009Time: 8:10:44 AMUser: N/AComputer: call managerDescription:Error: DeviceTransientConnection - Transient connection attempt. Connecting Port: 2000 Devic...
bbtekgraf by Level 1
  • 1845 Views
  • 10 replies
