IP Telephony and Phones
Labels
Hello Experts,We have several VG204 devices configured using MGCP connected to fax machines. We are having a problem when the VG boxes are busy with a fax and a second incoming fax machine does not get a BUSY from the VG box. It rings until deciding ...
G3261 by Level 4
  • 856 Views
  • 6 replies
Hi Folks, Need quick suggestion on the dtmf method usage for the below call follow: PSTN >> PRI >> VG >> MGCP >> CUCM >> SIP Trunk >> CUBE VG supports - OOB CUBE supports - RFC2833 DTMF on SIP Trunk configured as: No Preference: Will the trunk ut...
