CFA is showing the Original Called Number and not the Masking Number
Here's the scenario,
We have a DN, lets say (03 1111 2222) which we have configured a different CLI ( 03 1111 3333) using Calling Party Transformation when making any external Calls. We set that Transformation CSS at SIP Trunk Level.
In a scenario where it makes any externals Calls, the other party observes the Masked number
 DN ( 03 1111 2222 makes PSTN call) >  SIP Trunk > Mobile User (observes Caller ID as 03 1111 3333)
But In a scenario, where DN has set the CFA to mobile, it doesn't show the masked number
Incoming PSTN Call to DN 03 1111 2222 > CFA (Mobile 04 5555 6666) > SIP Trunk > Mobile User (observes Caller ID as 03 1111 2222)
Not sure if it is do with Calling Party Transformation should be done at Device level for this particular scenario
OR
It is to do with Calling Party Selection at SIP Trunk Level which is currently set as Last Redirect Number
OR
It is to do with SIP header manipulation at CUBE Gateway level
Would appreciate if we can get responses If someone has already been to this situation and knows what needs to be done.
Taha
Another  option and this will suit your request.
  • Check  Redirecting Diversion Header Delivery - Outbound option.
  • Uncheck Use Device Pool Redirecting Party Transformation CSS
  • Use  your calling party translation CSS  as Redirecting Party Transformation CSS.
Response Signature
One option will be :-
  • on DN  2222 use  external phone number mask 03 1111 3333.
  • On Route Pattern Use Calling Party's External Phone Number Mask
  • on Trunk use Last Redirect Number (External)
Response Signature
Response Signature
